Recaro Pole Position Mounting
Hi guys
What is the best way to mount Recaro pole positions in a Cayman? Can I bolt Recaro alloy sidemounts straight to the floor?
I want the lightest way possible and don't want sliders as they won't need to move
Jon
Jon
Without some tweaks I don't think you can bolt the risers directly to the floor. You can use the below adapter, and bolt the riser to the below adapter (note the angled front bolt). Or you can bolt the below adapter to a slider and the slider to the riser.
http://www.bkauto.com/R_9040_Seat_Tr...r_p/r-9040.htm
I have these adapters if you need them.
