Engine compartment cooling question
Hello all!
New owner of a 2010 Cayman.
I'm getting to know Porsche as this is my first but so far I love it!
I searched around but can't find a definitive answer so i'm posting.
Is the engine compartment fan constantly on while driving? Or is there natural airflow from the vents and the fan only comes on when needed?
I'm sure i'll have tons of questions later, and rest assured I prefer using the search function when possible!
Thanks!
Marc from Quebec, Canada
Thanks!
I've observed the same thing Dave. But while the car is running i can't hear it.
That's why i'm wondering if it's always on and we can't tell or if there's air flowing naturally in the compartment during "regular" driving.
Obviously when you turn off the engine, the fan would turn off (if it was on) and then turn back on if needed.
So the question remains!!!
I believe it is engine compartment temp related.
You're absolutely right Mikew968, but i'm wondering if, let's say, highway speeds cause enough airflow or if the fan is absolutely needed in all cases.
Obviously in traffic and low speeds, if the temps reach that point, the fan comes on, but what about going down the highway at 50+ mph?
The fan only comes on when engine and engine compartment temps rise to a certain level and (in the 987 generation at least) the fan is on the right side of the car only.
You should be able to hear the fan with the passenger window open if you are stopped next to a wall or other sound reflecting surface. I also hear it when someone opens the passenger door.
Thanks Spokayman, but my question remains. Does the fan "need" to turn on at highway speed?
I'm not looking to modify anything, just trying to understand how it's been engineered.
Let's say you spend 3 hours at highway speed. Does the fan cycle on and off or is there sufficient airflow to not need the fan during that period.
Thanks Spokayman, but my question remains. Does the fan "need" to turn on at highway speed? I'm not looking to modify anything, just trying to understand how it's been engineered. Let's say you spend 3 hours at highway speed. Does the fan cycle on and off or is there sufficient airflow to not need the fan during that period.
