Help ID these KW Shocks?
Hi, I have KW Shocks that came on the track car I purchased. It's a 2006 Cayman S. Can anyone identify the model of the shocks from the attached photos?
It looks like there is rebound adjustment only, unless I'm missing something, but they have the side-reservoir.
front top.
Front Shock
Rear top
top of the front reservoir
bottom of the front shock.
front top.
Front Shock
Rear top
That is not bottom of the shock on last picture. Find bottom of the shock (above arm) and see if there is adjuster there. Usually it is little pin with holes sticking out or allen. If there is adjuster probably V3 or clubsport.
Ah, of course. I'll take a close look next time I'm with the car, which probably won't be for a couple of weeks. Thanks.
