RSS | Lightweight Racing Exhaust System "Grand Am Cayman Cup"
RSS | Cargraphic Lightweight Racing Exhaust System "Grand Am Cayman Cup" | Now Available!
Direct Website Link: https://roadsportsupply.com/cargraph...oxster-cayman/
Full Lightweight Racing Exhaust System Grand Am Cayman Cup
- for Porsche 981 Boxster / Cayman / 2,7l / 3,4l / 3,8l
This Lightweight racing exhaust as used in Grand Am Cayman Cup
has been developed and tested to the highest standard
on the dyno.
The silencers are designed as absorptive silencers which
reduce exhaust back pressure drastically.
In combination with a pair of equal length long tube
manifold set without integrated catalytic converters
(NOT OBD2 compliant / ECU reprogramming required)
the resultis beside more power and torque a better
response characteristic.
Further evidence of improvements made, are recognised
through an enhanced accoustic and weight reduction.
Strenghtened brackets as well as the olive- and slide
system ensure an exact adjustment, which guarantees
a stressless installation.
Developed for maximum flow the equal length long tube
primaries merge through a racing style spliced collector
with spike and create the following further advantages:
- Reduced backpressure
- Reduced temperature
- Maximized performance
- Enhanced sound
- Weight reduction
- Lasercut machined stainless steel flanges for
accurate plain fit
PERFORMANCE
+20kW(27PS) more power and 35Nm additional torque
The system includes:
1x RACING manifold set without integrated catalytic
converters
Ø 2.0" (51mm) extra long primary pipe length
1x Flex pipe set which allows maximum movement under
heat and absorbs vibrations
Ø 2.5" (63,5mm) pipe work
1x Lightweight race silencer set RACE-X with integrated
2x89mm tailpipes
1x Fitting kit pipework
on the dyno.
- Enhanced sound
- Weight reduction
accurate plain fit
PERFORMANCE
converters
2x89mm tailpipes
