Will my wheels fit my Cayman 2007
Hello, I bought a set of used oem wheels, front 19x8 and rear 19x11.
I am planning on buying 305-30 ZR19 rear and 265-30 ZR19 front.
I have 7mm spacer in front and 25mm in back
Can anyone tell me if those tires will fit my 2007 Cayman???
Thanks in advance
Thanks in advance
Thanks for you replies, I am not sure what the offset measurement is, I will measure it and post it tonights?
I made a mistake, the width of the front will be 245.
I will also verify if I can reduce the width of the rear based on my wheels...
For the rear wheel, If my measurements are right, the offset is 2.75 inches.
If we take into account the 1 inch spacer then the actual offset would be 1.75 Inch???
For the front, the offset is 1.75 I have a .275 spacer in front if need be.
Rear you may run in to strut or fender.
The 8" front will be okay with a 7mm spacer.
Are you sure it reads "11 57" and not "11 51"? Factory widebody 997 cars came with a 51 offset.
If it indeed reads 51 you're looking for a 13-14 mm rear spacer so the effective offset is around 38 or 37. You could probably run a 15 mm spacer but will likely rub on the fender under load running a 305 tire (depending on tire brand/model). Much better off running a 295/30 tire.
You're gonna need a ~30mm spacer in the rear to clear the struts on the inside. Test fit with 25 mm and see if the inside of the wheel hits the strut. Temporarily stack the 25 mm and 7 mm and confirm if it clears.
