Will my wheels fit my Cayman 2007
Out of storage ;-)
that's pretty drastic, like 1 1/4". I'd start with something less, but first mount the tire, lay it flat on a bench, then pull it toward you till you can measure the distance to the rim lip, add 10 mm and get the nearest size spacer. One approach.
The measurement I gave you is with a 1 inch spacer. The problem is that I dont have a tire to mount, thus is why I am trying to figure it out before buying tires at near 500$ a piece...
I had a near identical issue with a set of Carrera S II wheels off of a 2009 Carrera S- 35mm spacers in the rear did the trick, but I had a little bit larger offset than you. Here's the thread
https://rennlist.com/forums/987-981-...-possible.html
A 305 is a lot of tire to stuff into the rear of a Cayman. If you get the offset right or proper amount of spacers to keep from rubbing on the inside, I expect you'll need to roll the fender flanges outboard. I ran some Pirelli slicks that were 285 and had inside rubbing.
