Used Cayman 2nd Gen check list
IMO, the S is not underpowered, and the base also has enough power unless you are on a long track.
Those who say Porsches are underpowered are often comparing against the torque of larger 6 and 8 cylinder engines, and I used to think this way too because I was used to muscle cars.
One of the things that makes a Porsche different is the performance of the engine in the 3.5K - 5.5K RPM range. Until I learned to keep the RPMs up in my Porsches I too thought they were underpowered and kind of "dull".
As others, I have found that there is a fair amount of difference in ride smoothness between 17" and 19" wheels sizes. I have not experienced PASM, so I cannot tell how much that would compensate for the brittle ride of larger diameter wheels.
As far as a checklist for the 987.2 generation, I would say that it would be very similar to the 987.1 generation. There is no IMSB to worry about of course, but otherwise the maintenance and repair items are pretty much the same. A good PPI goes a long way toward discovering any necessary repairs, and I consider maintenance history to be even better at determining the long term health of a car.
Dave, have you driven a Cayman base before? How different did it feel?
I wouldn't spit on the extra hp of the CS but I'm not going to track this car so the stock 265hp sound alright. I'm used to drive older cars with less power so I'm not too worried.
Otherwise, can someone explain me why the rim size seem to have such an impact on the ride smoothness and which rim size would you pick?
I like 18 and 19, 17 seems too small IMO.
thanks
thanks
thanks
thanks
Dave, have you driven a Cayman base before? How different did it feel? I wouldn't spit on the extra hp of the CS but I'm not going to track this car so the stock 265hp sound alright. I'm used to drive older cars with less power so I'm not too worried. Otherwise, can someone explain me why the rim size seem to have such an impact on the ride smoothness and which rim size would you pick? I like 18 and 19, 17 seems too small IMO. thanks
thanks
thanks
Gary and Dave, are you pretty much saying that the base cayman isn't a good DD since I won't shift at 6.5k rpm on my neighboring roads and freeways?
An '09 S with PSM seems out of my budget.
Very useful advices on the tires, thanks. I'd probably go for a 18", could you link me to one of these tires with bigger sidewall? or just what your pick would be for comfort/occasional sporty drive rather than track/performance?
thanks all.
thanks all.
thanks all.
thanks all.
thanks all.
thanks all.
thanks all.
thanks all.
Hey guys, new to the forum here. I am also looking to buy a Porsche Cayman base or S or boxster base or S. I am planning to spend between 40-51 k CAN $. I've done a lot of research and feel comfortable to be a DIY kinda guy with my car. I've literally checked everywhere on the internet of an average cost of maintenance per year to own a P car.
Im going to use this as a weekend car, so I was wondering can this beauty last me 20 to 30 years with regular maintenance such as reg oil changes? In my retirement i would splurge on a C2S or wtv catches my eye at that point. Please do not say like every person on the internet who doesn't know cars "If you ask about maintenance, you can't afford it"". Im simply trying to determine what it usually costs a regular owner.
1) What is the average costs per year with the car in CAN $ if poss for a weekend car that will be used. I will not be afraid to put kms on it because my goal is to keep it.
2) Is it only 911s that can last 20-30 years or can a cayman bought used with PPI and me doing the work regularly last me a nice 20-30 years without major services that would cost me 4-5k. (yes i know a new car can have unforeseen problems such as with a used car, but some cars are known to break)
Thanks for any tips, i really appreciate the advice and comments and the love for Porsche. Im obsessed with this badge and cant seem to shake it off
And maintenance costs can vary considerably year to year
You may not spend much beyond oil, filters, spark plugs, etc. for years, and then you might find the shifter cable breaking, the water pump leaking, the AOS leaking, etc. and you will be into several thousand dollars in short order.
Compared to the average car Porsches are expensive to maintain. Parts are expensive, Dealer labor is extremely expensive, and many repairs and maintenance are labor intensive.
Doing maintenance yourself will save quite a bit a money, but there will eventually be components that wear out and break that you will likely not be able to replace or repair yourself.
I can give an example from my own experience.
In six years I have spent about $1,600 in maintenance on my '06 Cayman S which is just a weekend and good-weather car for me. I do nearly all of my own maintenance and this cost is just oil, filters, battery, brakes, belt, etc. No real repairs have been needed.
I've also spent about the same amount in modifications that I've undertaken, and then another $1,500 in tires.
Within the next 5 years, there will likely be $3,000 to $5,000 in more major maintenance and repairs needed in addition to the approx. $300/year plus tires that I have been spending.
If you don't have a several thousand dollar repair budget saved up, you might reconsider whether buying a used Porsche (or any high performance car for that matter) is a good idea.
IMO, Porsches are worth their cost, but they are not low budget machines.
No car will " last 20 to 30 years with regular maintenance such as reg oil changes" unless you don't drive it, and even then tires, belts, and anything made of rubber that is a wear item will eventually need to be replaced to say nothing of mechanical and electrical parts that simply stop functioning properly.
If you are worried about longevity, when it comes to performance cars, well they don't get much better than Porsche. Look through for sale ads where you can a substantial number of older, high mileage, well maintained cars. Why, first just good ole plain engineering as a foundation. Second, Porsche owners like to drive. Also, most Porsche owners don't skimp on routine maintenance and major wear item replacement. (Okay not always true of 944, 914 and 928 owners and some 996 owners now too.)
I have a 1987 944 Turbo with well over 225K miles on it. I wouldn't hesitate to take it on a long trip at all. In fact, I regularly track it where it's rock solid. I attribute this all to all it's owners maintained it. Everything from regular fluid changes, belt and hose servicing, fuel line servicing, suspension bushings replaced as they aged...you name it, if it was a wear item, it was serviced when it was needed.
Find a car with solid service records, don't skimp on any service need or interval and DRIVE THE CAR. All the servicing in the world will be undermined by a lack of use. Tires get flat spots, seals, gaskets and hoses dry out and vermin get in make a home and do all kinds of damage. Mice sure do like to chew on electrical wiring for some reason. They also love to devour insulation, seat foam and such to use as nesting material.
So go find that car then drive it like you stole it!
Thanks for the replies guys really appreciate it.
1)SPOKAYMAN: Thanks for the detailed info! The maintenance list you do yourself on the car (oil,belt,brakes etc) is what I want to do. I am no mechanic so definitely aware of unforeseen repairs or repairs i simply can't do will cost more than a honda. Thing I will need to search is for indy garages in Montreal to avoid paying dealer costs that are expensive for nothing.
2) GARY R.: What i meant was that if i followed all regular maintenance schedules, so changing oil, fluids etc without cheaping out, I wanted to know if a cayman was as solid as a 911 which some are 30 years or older and still work!
3)CATAMOUNT: Wow that is truly amazing. As you saw in my posts, my goal isnt to garage queen the car and service at dealers to have a higher resale because I want to keep the car for a very long time, maybe even bury it (if it dies since it seems they really are bullet proof ) I'm planning on using it as a weekend car and not to DD it to make it much more enjoyable. I will put KMS and will use it 6 months a year, but I am now more confident I can keep that car for a long period of time.
I see most owners mainly only do oil changes, fluid flushes when it reaches time to change and basically thats all unless some major service occurs which i guess can be different for each car/owner. I am ok to budget, but just afraid it will cost 2k-3k a year to run. I dont include tires or breaks because that depends the driver and to me is not really maintenance. Thanks for answering and still looking for information of maintenance costs down the line (6 years or more of ownership) since i will not purchase new, and problems usually don't occur at the beginning. Your input is appreciated and I can't wait to purchase this beast and join a Porsche club and do some rallies.
As a previous owner to a 5 air cooled 911's I think what you fail to understand is that it costs 10-20K to rebuild (any) air cooled 911 motor. If you think you can go 20-30 YEARS without digging deep into your pocket somewhere along the line for ANY Porsche you need to re-assess your car choice. There is no magic potion or oil or prayer to avoid a major issue, it's luck of the draw when all things are equal. I just read an article where they stated that you should change the oil frequently to avoid IMS issues in early (97-2008) water cooled boxer engines. It's an idiotic statement if you know why IMS bearings fail, but it was in a major publication..
