SLOTTED SHIFT KNOB
Basic Sponsor
SLOTTED SHIFT ****
FUNCTION-FIRST Performance strives to reconnect drivers to their vehicles with the new SLOTTED SHIFT ****
Our Slotted Shift **** is machined from solid billet 6061-T6 aluminum to ensure that all shifting effort is transferred to the shifter, not lost to a flexing shift ****. The 2-inch diameter fits firmly in the palm, and is spaced high up to keep the shifting hand clear of the shift boot. The **** is designed specifically to fit Porsche’s rectangular shifter shaft, and attaches securely via high-hold cone point set screws. Mounting height is customizable, ranging between 0.25-inches lower and 1-inch higher than stock.
The distinct slotted design reduces weight and delivers a no-slip grip, all while effectively shedding away the heat that commonly plagues standard billet shift *****.
Shift boot integration is not an after-thought. Our unique collar affixes the shift boot cleanly under the base of the **** - it does not “puke” out the top, as with other aftermarket and early OEM shift *****.
Two color choices:
Silver (clear anodize)
Black (black satin anodize)
Current fitment is for manual transmission 987s only!
If there is interest for 981 fitment, please let me know, and I can work on developing that (the shifter shaft on the 981 is different than previous generation Porsches).
Please click here to check out the product page for additional pics, details, and installation instructions.
Comprehensive Shifting Solutions for your Porsche.
Basic Sponsor
Announcing version 2 of the SLOTTED SHIFT ****...
We've moved to a 2-piece design (like the CLASSIC SHIFT ****), and Shift Pattern engraving is now available. Choose your pattern and whether you want paint-fill or a bare engraving.
The base shafts are now also available in either standard or extended heights.
