TPMS
TPMS
I have a 2008 Cayman S that recently has been giving me a false reading on the left side tires. It started out as just the left rear and about a week later included the left front. The display shows the pressure on the both rears as being the same yet it also says I need to add four psi to the LR. I checked the pressures on both sides and they were both the same. As an experiment I added air to both the the LF and LR and this cleared the alert on the display but then came back two days later even though the left side tires had more air than the right side. Anyone have any idea what could be causing this? Thanks.
Batteries are in the TPMS sensor units inside the wheels. To replace the batteries, you must replace the TPMS sensor units. Many have had good luck with these reasonably priced units.
http://www.oewheelsllc.com/TPMS-Sens...e#.VBp8BVbw45E
Eddie
Eddie
