Motor vibrating
Motor vibrating
Hello,
I have an 08 Cayman S with 20k on it. The motor starts to vibrate like an unbalanced wheel at about 1800 RPM. I am going to take it to the dealer but wanted to get some opinion here first. Any ideas?
If check engine light on then error code would provide a hint as to what's wrong. If check engine light on there are too many possibilities.
You might check with service manager before you take car in and see if he advises against driving the car any and instead wants you to have it flat bedded in. Car should still be covered by Porsche's road side assistance program so tow is free.
Sincerely,
Macster.
There is always a concern of attempting some sort of self-diagnosis in that there's a risk of doing more harm, making a small problem into a major one. Even though car covered by warranty you should try to avoid making the situation worse.
The most important thing is that you know when the symptom appears and can convey this to the service manager so someone there can reproduce the symptom at will.
When you get the car back be sure to ask what the source of the vibration was and post back here. I for one am very interested the source of the vibration. Kind of an unusual symptom.
Sincerely,
Macster.
Depending on the vibration and distance to dealer, either flatbed it or drive it but seriously, don't even waste time wondering on the forums. This sounds important, could be engine mounts or something else, get it to the dealer ASAP!
