Evap code?
No on the car running while filling. I've cleared the code once. I'll check the gas cap and clear it again. Would be nice if it just needs a new gas cap....
Gas caps are 26 bucks from ECS. It's what I would start with if you have no other codes or obvious leaks. Beyond that - and I'd likely take it to the dealer. I'm not a fan of troubleshooting emissions codes related to the evap system.
Start with new gas cap. If code returns - its most likely the evap purge valve....located on the driver's side of the intake plenum. An $80/shipped part and 30min to fix. Are you getting hard starts after gassing-up?
It was the cap on mine. Good luck
Ok, replaced the gas cap and all was well until yesterday when the light came back on. Dammit!
The truck is harder to start right after I fill it up.
So what's my next move other than take it to the dealer?
