295 tires on 20x9 rims anyone?
That's going to handle like **** with that much sidewall hanging out over the side of the rim. Plus, it's going to bulge in the center with the correct pressures, and you'll wear through them pretty quick. Since it's the wrong size for that rim (not even within the range of sizes), you won't be eligible for a manufacturers thread life warranty.
Go with a 21" GTS setup if you want a wider tire or more grip. Trying to stuff a really big tire on a fairly small rim is the wrong way to go about it.
