Could removing intake cause P0455 code?
I had to have my starter and battery replaced in December, which entails removal of the intake manifold to get to the starter. The day I drove it home it popped a CEL code P0455 (major evaporative leak). My dealer swears that nothing they did could have caused this code. I needed an oil change so I had my indy do that. They also do repair work and I had the extended warranty. They did a smoke test and replaced the evap canister (also under warranty). The code came back immediately. The dealer still doesn't think they caused this CEL but I think they may have not connected the intake manifold back correctly. What are ya'lls thoughts?
There is a diagram here for the 996 series that shows a line to the intake manifold. Maybe just a leaking gas cap.
http://www.renntech.org/forums/topic...code-is-p0455/
Sure enough, the dealer found a unhooked vacuum line to the intake that was causing the code. I still I am not sure that the evap canister needed replacing as well, but my indy mechanic swears the smoke test lead him to a faulty canister. I just can't see both things happening at the same time.
Nope, no discount offered but didn't charge anything for repair. I always seem to get detailed surveys from Porsche North America after any dealer service. This one will not be pretty for my dealership.
