05 Cayenne V6 issue: Rough idle at start up, when idling at stop lights
Old 12-23-2015, 04:05 PM
rob76turbo
rob76turbo's Avatar
Default 05 Cayenne V6 issue: Rough idle at start up, when idling at stop lights
Has 106K miles. replaced plugs / coils about 30K ago. NO CEL.
So at start up, the truck idles very roughly, until you drop it in drive and accelerate. No issues during acceleration / running. But it vibrates again when idling at a stop light. Revving the motor cures the rough idle.
Maybe crank case vent valve? I would think if it was a vacuum leak or secondary air / fuel pump, it would throw a code?
Stumped!!
Thanks,
Old 12-24-2015, 04:37 PM
rob76turbo
rob76turbo's Avatar
Default Could it be motor mounts?
I was also thinking it could be motor mounts. The vibration is only in park or in drive at idle. Goes away once under way or by pressing the accelerator
I have done a lot of searches, but nothing seems to match up with what I am experiencing.
thanks again!!
Old 03-09-2016, 07:33 PM
kalyan
kalyan's Avatar
Did you figure out what was wrong? I am having similar issue as well.
thanks!
Old 03-09-2016, 09:41 PM
endless_corners
endless_corners's Avatar
Sticky throttle body could do it. Look through here for a few possibilities. http://www.pelicanparts.com/techarti...yenne_Tech.htm
Old 03-10-2016, 03:23 AM
kjbu
kjbu's Avatar
Maybe it's time for replacing timing-chain. The V6 has a design fault in timing-system. Mine was replaced at 130k km.
Old 03-10-2016, 08:55 AM
rob76turbo
rob76turbo's Avatar
Ended up replacing motor mounts and intake gasket (which was leaking badly). That cured it to the tune of $2300. Very tired of spending $$ on this suv.
Old 03-10-2016, 11:48 AM
kalyan
kalyan's Avatar
Thanks for your input, rob76turbo. I was thinking the same too. I will check the mounts this weekend.
Endless: I will check the throttle body as well. It is easy to check.
kjbu: Mine is a V8.
Thanks all...
Old 03-16-2016, 01:36 PM
kalyan
kalyan's Avatar
Update: It was the engine torque damper/strut. Replaced it last night and engine is smooth and quiet.
Old 05-17-2016, 07:11 PM
PorscheMonster
PorscheMonster's Avatar
Wait so engine damper is code word for engine mount?
Old 05-17-2016, 07:18 PM
kalyan
kalyan's Avatar
Engine damper is on the top of the engine while the mounts are in the bottom. different things...
Old 05-17-2016, 10:04 PM
deilenberger
deilenberger's Avatar
Received 1,140 Likes on 758 Posts
Thanks for posting the solution - it makes a thread like this so much more valuable to someone facing the same symptoms..
Old 05-31-2021, 03:39 PM
Edwinner
Edwinner's Avatar
Default Is engine mount replacement a easy job?
Hi Rob, I have 2009 V6, with the same symptoms with yours except rough idle.
I am thinking engine mount issue. So did you remember how hard to replace it? Is that possible to DIY?
thanks
Old 05-31-2021, 09:47 PM
Ericson38
Ericson38's Avatar
thanks
I recall in one of these rough running VR6 (DFI like yours) scenarios that it ended up being an injector leaking badly. They had been through the plugs and much more, ending up pulling the engine, getting another...
Bottom line was the original engine was made whole again after the dribbler was isolated and replaced.
Keep an eye on your oil level and smell for gas.
Rob I'm sure has the link to that story.
Old 06-02-2021, 06:38 PM
Shawn Stanford
Shawn Stanford's Avatar
The times my VR6 has run rough, it was because of a failing coil.
Old 07-01-2021, 03:50 PM
sloanautomatic
sloanautomatic's Avatar
Does this video resemble what you guys were experiencing? My 955 cayenne does not accelerate at first attempt. Almost like it is trying to find the gear? But after that first attempt, it seems to accelerate normally. But the grinding rhythm in that video continues for about another ten minutes. I feel it in the small of my back, coming in and out.
Quick Reply: 05 Cayenne V6 issue: Rough idle at start up, when idling at stop lights
