Cayenne 955 and 957 exhausts. Turbo vs CayenneS
I want to fit an aftermarket exhaust on my 08 turbo cayenne. Found one second hand for sale but it's for the 955 CayenneS.
Does anyone have any idea if the exhausts are the same?
Will a 955 CayenneS exhaust fit on the 957 Cayenne Turbo
Thanks,
Thanks,
my guess is that since the system you are considering is already "aftermarket", there could be any number of modifications that were made underneath.
So beware that even if you get one of the 955 & 957 Guru's to chime in here & tell you if they are both exactly the same (which I highly doubt),... you may still not be out of the woods (ie, it still may need further modification to make it all work).
If you gave us more info about what you are trying to achieve,... you may get more responses (& of COURSE you will get ton of opinions!!,... but that is a GOOD thing, since it gives you more to think about. Choices are good!!).
In other words: Are you simply trying to get a cheap replacement since yours is all rusted out? or Are you trying to get more sound out of it? Do you want that sound to be louder ALL the time,... or only when you need it, or want it (like a push button / valve system)? .... those kinda things....
Won't work. You're comparing a 4.8 Turbo exhaust to a 4.5 NA exhaust. One is made to have the least amount of back pressure while the other is made for timed exhaust pulses.
