Key Stopped working - New one doesn't work either
Old 09-27-2015, 09:32 PM
PupC
PupC's Avatar
Part should be here in a few days..will try that 1st...
How does the kick plate come out anyway?
Thx
Pup
Old 09-27-2015, 11:00 PM
Sniffer
Sniffer's Avatar
Originally Posted by Brit6
That I am not sure so I can't comment. I have never had the shifter problem. I would fix that first and re-assess.
I would agree with this advice, fix known issues and see where that leads to avoid fixing stuff that aint broke
Old 09-27-2015, 11:59 PM
Brit6
Brit6's Avatar
Pelican parts is your friend
http://www.pelicanparts.com/techarti...el_Removal.htm
Thx
Pup
Old 09-28-2015, 08:56 AM
PupC
PupC's Avatar
Perfect!
Thanks Brti6...
BTW, What part of the great white north do you reside?
Pup
Old 09-28-2015, 11:16 AM
Brit6
Brit6's Avatar
The capital of the country........see if you can guess without google.
Perfect!
Thanks Brti6...
Pup
Old 10-05-2015, 10:06 AM
PupC
PupC's Avatar
Replaced the Shift gate trim, no luyck. When I turn off vehicle , I still get "Shift into Park" message...
Now I have a check engine light too! Cleared it with Durametric, but it came back. Will have to take a pix of screen and capture exact error... P error, referring to "CAN" error.
Also, rec'd parts from Mouser for Kessy unit, haven't had time to attempt the fix yet... Stay tuned.
Pup
Does anyone ever get ALL of the electrical issues ever resolved? Sheesh
Old 10-07-2015, 08:45 AM
PupC
PupC's Avatar
Question
Nothin'?
Old 10-07-2015, 10:25 AM
mtnrat
mtnrat's Avatar
Have you replaced your battery? Also if you have been playing around under the hood those brittle plastic hoses often crack and throw a CEL. What codes do you have?
Old 10-07-2015, 10:31 AM
PupC
PupC's Avatar
Battery in Key has been replaced...
New Interstate Battery being installed after work.
Which vacuum lines are you speaking of? Any pix...
Lotsa codes, had pix, but were out of focus... Will run scan after new battery and post new pic...
Check engine light came on again this morning...
Old 10-07-2015, 10:48 AM
mtnrat
mtnrat's Avatar
This one I had trouble with. Tried duct tape for a temp fix. May not be that at all. Wait for the battery and see what you get.
Quick Reply: Key Stopped working - New one doesn't work either
