70 57 19 Removing and installing A-pillar trim
Old 06-30-2015, 03:53 PM
cchardwick
cchardwick's Avatar
Default 70 57 19 Removing and installing A-pillar trim
Does anyone have this technical article for a 2004 Porsche Cayenne S? I think this is what I have to remove to access the washer fluid line that runs overhead in the cabin, it's leaking down into my dash.
Old 06-30-2015, 06:08 PM
cchardwick
cchardwick's Avatar
OK, I think I may have it figured out, I've been searching the web and could only find one reference to this. Looks like there is one screw behind the 'airbag' logo button on the pillar, so you take out one screw and just pull on the pillar real hard to get it off, correct? Should you use a plastic tool to try to pry it off? I do have a plastic tool set...
http://www.ferdinandmagazine.com/fer...aintenance-101
Old 05-11-2019, 05:52 AM
terrygraves
terrygraves's Avatar
Default trim removal technique
I have an english cayanne the piller cover in on the left hand side so no air bag logo. Did you lever the cover off using plastic levers or just pull it off?
http://www.ferdinandmagazine.com/ferdinand-porsche-cayenne-diy-menance-101
[/QUOTE]
Quick Reply: 70 57 19 Removing and installing A-pillar trim
