2011 cayenne v6 oil change torque specs
Hello
I am planning on changing the oil on my 2011 Cayenne V6 and I am looking for the the torque specs on the drain plug and the oil filter (both oil filter drain and the housing itself). I have found the v8 torque spec posted here but not the V6. Anyone have the factory manual spec?
Thank you
Thank you
Received the answer from a kind person on another site. According to Porsche service manual section WM170117 the oil drain plug is 30 nm and the drain plug on the oil filter cover is 10 nm
