P2235 P2237 P0011 codes
Old 04-23-2015, 10:35 AM
seafeye
seafeye's Avatar
Default P2235 P2237 P0011 codes
Check engine light is on. Used the durametric to get the codes. I just did change the valve cover gaskets not too long ago. Not sure if that would be related. could it be the camshaft sensor causing the P2237 and P2235?
Quote
Work Log
Bosch Digital Motor Electronics 7.1.1
Module Identification
VW Part Number 8SLVAKN00000 Controller ID 0134 Current Fault Codes
P2235
Lambda control adaptation at idle, Bank 1 - Upper limit value exceeded, test conditions are not-completed, fault is currently active and causing a DTC light
P2237
Lambda control adaptation at idle, Bank 2 - Upper limit value exceeded, test conditions are not-completed, fault is currently active and causing a DTC light
P0011
A Camshaft Position -Timing Over- Advanced or System Performance B1 - Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light
Old 04-25-2015, 12:05 PM
seafeye
seafeye's Avatar
I'm about to buy a pair of Cam Sensors. I understand that people have changed them without removing the intake manifold. Should I just go ahead and remove the manifold anyway and replace the gaskets?
Quick Reply: P2235 P2237 P0011 codes
