PCM map stuck
Old 07-22-2014, 01:31 AM
SKYSTAK
SKYSTAK's Avatar
Default PCM map stuck
My 08 s pepper nav is acting weird. It is stuck in one place in map mode, but changes to where I am for turning directions and still gives correct voice directions. The nav page, when not in map mode, also gives proper read outs but when i push map it till is stuck. I reinserted the disk, no joy. Any advice?
Old 07-22-2014, 10:36 AM
hahnmgh63
hahnmgh63's Avatar
Try a hard reboot by pushing and holding down the 1,4, and 8 buttons on the left until it begins a restart and see if that works.
Old 07-24-2014, 01:07 AM
SKYSTAK
SKYSTAK's Avatar
worked thank you
Old 07-24-2014, 10:06 AM
hahnmgh63
hahnmgh63's Avatar
Occasionally my PCM will do some strange behavior that a hard reset is the only way to clear it. When you do the hard reset all of your memory functions still work fine but you will loose the most recent trip memory stuff.
Quick Reply: PCM map stuck
