check coolant level warning :Coolant level sensor issue?
2004 Porsche Cayenne S, with 120,000 miles.
I get check coolant level warning often. The coolant level is fine and the temperature indicator is in the normal range. I am assuming that this is Coolant level sensor issue right? If so where is the sensor located? Has there been any write ups on the replacement procedure? I appreciate any helpful input on this issue
Chamilka
Chamilka
