04 cayenne s tire question
I have a 2004 cayenne s awd and its time for new tires. I have a guy that is wanting to trade me wheels and tires for an old dodge I have. However I do not know if they are going to fit on my cayenne. any help would be appreciated. thanks
current tires are continental 275/45r19
trade tires are Michelin p275/45r20 106v ? and he says rims are a standard 5 lug and should fit any premium suv
can someone please help me... I cant contact a tire store to verify untl at least Monday!!!
It is not just that they are five lugs, they need to be 5x130 and have the proper offset in addition to being hub centric to the car. Post a picture of the wheels and maybe we can identify if they are Cayenne wheels.
Formerly 'slevy951'
Google found this....
Dodge Trucks and SUVs Year Bolt Pattern Stud Size Lug Style Center Bore
Dodge 1/2 and 3/4 Ton Trucks '79-'93 5 x 5.5" 1/2-RH Nut 77.8mm
Dodge 1/2 Ton Pickup and Van '49-'70 5 x 4.5" 1/2-RH Nut 71.5mm
Dodge 1/2 Ton Pickup and Van '71-'85 5 x 4.5" 1/2-RH Nut 71.5mm
Dodge D-50 & RAM-50 (Turbo Diesel) '79-'93 6 x 5.5" M12 X 1.5 Nut 108mm
Dodge Dakota '05 & Older 5 x 5.5" 9/16-RH Nut 77.8mm
Dodge Dakota and Durango '91-'03 6 x 4.5" 1/2-RH Nut 71.5mm
Dodge Dakota and Durango '91-'04 6 x 4.5" 1/2-RH Nut 71.5mm
Dodge Dakota '05-'08 5 x 5.5" 9/16-RH Nut 77.8mm
Dodge Dakota(LE, HD) '87-'90 5 x 4.5" 1/2-RH Nut 71.5mm
Dodge Dakota '87-'90 5 x 4.5" 1/2-RH Nut 71.5mm
Dodge Ram 1/2 Ton Trucks '94-'01 5 x 5.5" 1/2-RH Nut 77.8mm
Dodge Ram 1/2 Ton Trucks '02 & Older 5 x 5.5" 9/16-RH Nut 77.8mm
Dodge Ram 3/4 Ton Trucks '94 & Older 8 x 6.5" 9/16-RH Nut 122.5mm
Quick math says 4.5" is 114mm, 5.5" is 139mm. I'm going to vote that they wont' fit.
Rocky Mountain High
I agree with your vote that they probably won't fit. Even if the bolt pattern is correct, Porsche vehicles require specific offsets.
