will 957 wheels fit on 958 Cayenne
Hi, I want to put winter tires on my 2013 Cayenne and was looking at used rims. It seems that all that are available are older model wheels (957 S Cayenne model).
Will these fit on my car and, if so, will I need to have the dealer do anything regarding Tire Pressure Monitor sensor?
The question that should be answered is, are the bolt patterns the same? My 957 has a 5-130 bolt pattern. tirerack.com shows me the bolt patters are the same. I believe the answer to your question is Yes.
Bolt patterns on both generations of Cayenne's are 5x130, I believe that the hub is 71.5 on early model Cayennes and 71.6 on the new generation. I have tried the newer generation wheels on my 2006 (955) and they bolted up fine but seemed loose as on the hub, not a tight fit. I decided not to use the wheels because of this issue. Not sure if the .1 difference will allow you to put the early model wheels on the larger hub on the new generation.
Just my experience on trying to fit the newer generation wheels on older generation Cayenne's.
Thanks for your replies. I have read a few places where the Dealer is saying that older wheels are not compatible with the newer model cars. Didn't want to risk it so did find some slightly used 958 rims with brand new snow tires for about $3,000 so decided to go ahead and get them installed. I just hope that the Tire Pressure Sensor Monitor works.
Will have them installed on Saturday.
