04 Cayenne S stuck in 4wd PLEASE HELP!
hey guys,
I have an 04 cayenne that has been running fine. Well we got a load of ice here in Texas and I had to get out in it. I put the car in the the low 4wd mode wich it seemed to do without issue but I thought better of it and tried to put it back in "regular" drive mode. However it's stuck in low. when I turn the car off and then back on, I try to turn off 4wd it does nothing for several seconds and then a "4wd system faulty" comes up on the screen. I've tried everything I know to get it back in normal mode but I'm out of ideas. So a couple of q's... Is there a way to manually take it out of 4wd? are there any fuses/switches or whatnot that could be the culprit? Could the unusually cold weather have anything to do with it not disengaging from 4wd? and finally what are the chances of it operating normally once the temp goes back up around here? I sure hope someone has some ideas
I'm a pretty good ways from any dealer and obviously naked.
Thanks in advance for any ideas.
John
John
Try reversing for a car length, then go to neutral and select drive mode. Hopefully it's just crotchety from not being used. Else its probably something electrical.
