Correct Rear Caliper torque values:
Old 04-30-2013, 09:59 AM
Km1.8t
Km1.8t's Avatar
Default Correct Rear Caliper torque values:
I have found different answers to this question. What is the torque specs for the rear caliper bolts on a Cayenne S? Some say 133 ft/lbs and some say 200 ft/lbs. I have a wrench that goes to to 150 ft/lbs and need to determine if I need a bigger wrench. Hope those bolts come out easy.
Thanks for the help.
Kevin
Old 04-30-2013, 10:27 AM
mudman2
Moderator !x4
mudman2's Avatar
Fronts are 200, rears are 133
Old 04-30-2013, 11:23 AM
Km1.8t
Km1.8t's Avatar
Old 05-01-2013, 09:47 PM
YRUNVS
YRUNVS's Avatar
Does someone have the caliper bolt torque values for the 958 V6 Black color caliper with 360mm front rotors 330mm rear rotors. Thanks Doug
Quick Reply: Correct Rear Caliper torque values:
