Vibration!!! Please help!!!
Hello all,
I have an '04 base model Cayenne, that has started to vibrate....
It's my wife's vehicle so she was driving it when the malfunction started, but I have driven it with the same results.
It's fine until apprx 25mph then the vibrating starts. It feels like a thumping in the center, but is definitely under the car. Most importantly when I am at speed (45-60mph) the vibration stops completely when I let off of the accelerator. It resumes commensurate with my use of the throttle (ie if I accelerate aggressively then the vibration is more pronounced, if I use just enough gas to maintain speed the vibration is present, but greatly reduced).
Was thinking it may be tranny or motor mount? But don't know if that would cause a vibration like that....
Any help or suggestions will be GREATLY appreciated!!!
Thanks,
Karl
Thanks,
Karl
Rocky Mountain High
Cardan shaft replacement is relatively inexpensive in the Porsche world, and it is a relatively easy DIY if you are so inclined...
