Updating mObridge/BT Software
Old 07-22-2015, 03:37 PM
  #61
Turboslut
Turboslut's Avatar
What was the outcome of this? What version did you try to update to?
Old 07-22-2015, 04:14 PM
  #62
Turboslut
Turboslut's Avatar
The wizard doesn't go past selecting Bluetooth or USD and then I just tried using the app on android and got authentication test failed...even though the phone is paired successfully.
Is anyone supporting Mobridge or do I yank this out of the car?
Old 07-24-2015, 02:07 AM
  #63
hindibuff
hindibuff's Avatar
Same problem here with android. Worked when it was at 1.9.4 but after updating to 2.0, it won't connect. Tried laptop with bluetooth but some errors. Heard of older versions working, but haven't tried them yet. Anyone have luck with pc/bluetooth based updating?
Old 03-12-2017, 11:15 PM
  #64
03aksuby
4th Gear
03aksuby's Avatar
Bringing this one back from the dead, I appologize. Is there any support for Mobridge/Parrot units remaining? I bought an 08 Cayenne GTS and it has an ABT2010 unit. I am trying to update the software via an SD card but am unable to find the .fif files on the web. Does anyone have these saved? Appreciate any help!
Old 02-05-2020, 09:33 AM
  #65
lider112
4th Gear
lider112's Avatar
Hello! I have last .fif files for ABT2010. I can send if you need.
Old 02-05-2020, 04:14 PM
  #66
Kevin M.
Kevin M.'s Avatar
Mine is bricked, cant add any more phones and can't remove old phones, I'll try your file if you don't mind.
Old 02-06-2020, 03:49 AM
  #67
lider112
4th Gear
lider112's Avatar
ABT2010_02.00.00
File Type: zip
Old 02-06-2020, 03:52 AM
  #68
lider112
4th Gear
lider112's Avatar
Files for bluetooth generation 1
File Type: zip
Old 02-06-2020, 03:53 AM
  #69
lider112
4th Gear
lider112's Avatar
Files for bluetooth generation 2
File Type: zip
Old 02-06-2020, 08:01 PM
  #70
Kevin M.
Kevin M.'s Avatar
Thanks I'll give it a shot!
Old 04-19-2020, 08:35 PM
  #71
NickRay
6th Gear
NickRay's Avatar
Anyone have any success fixing the MOST drop every 30 seconds or so? I am on 2.00.00 and BT 3.31. My mobridge ABT2010 works fine except for the MOST drop, making it pretty much useless.
Old 11-21-2021, 06:15 PM
  #72
utkinpol
utkinpol's Avatar
hi, i know it is an old thread - but maybe you know - i have got now much worsened issues with PCM reboots - PCM 2.1, 2006 997.1 car - navigation constant restarts, i think due to the mobridge interference - it got worse now with new iphone,
i was able to apply the patch you posted - the mobridge.txt was:
Software Version: 4 : 0 : 01.08.00 Boot Version: 4 : 01.00.07 Bluetooth Version: 1000 :: 01.70
and now is:
Software Version: 4 : 0 : 02.00.00 Boot Version: 4 : 01.00.07 Bluetooth Version: 1000 :: 01.70
after application of the of the bluetooth 1 file. it also had an 'upgrade failure' message showing, but it seems at least the primary software updated. the mobridge unit is old, from the 2009 time, with the SD card slot.
any idea if it is worth trying to update the bluetooth version software or is it futile?
Old 11-22-2021, 12:54 AM
  #73
oregondave
oregondave's Avatar
I’ve got a mobridge for cheap if anyone is looking!
Quick Reply: Updating mObridge/BT Software
