Key fob problem URGENT PLEASE HELP
Old 04-23-2011, 05:47 PM
pakimunda101
pakimunda101's Avatar
Default Key fob problem URGENT PLEASE HELP
So my key fob stopped working... it won't unlock the doors. I changed the battery and still won't work. Can I open the car with the key manually? will the alarm go off if I open the door? any other ideas? My wallet is locked inside the car and I cant get to it.
Old 04-23-2011, 06:09 PM
rudyrodriguez
rudyrodriguez's Avatar
If it's a 2011, you have a spare key in your key fob. Go to the drivers door handle and remove the handle cover. Then use your manual key to unlock the door
Old 04-24-2011, 11:01 PM
cordsig79
cordsig79's Avatar
when you open the car without the battery immeditaly put it in the ignition to disable the alarm
Old 11-11-2013, 08:45 PM
endless_corners
endless_corners's Avatar
Rather than make a new thread I thought I would post here..
So a month ago my keyfob had stopped locking and unlocking doors. I was fryed about it. Then I discovered if I pressed REALLY hard it would work. Then recently I dropped the key fob on the ground and it stopped working completely. So i took it apart and discovered the tiny little button soldiered to the circuit board had come loose. I re-soldiered the little guy back on and voila key fob works perfectly again. Sorry i didnt take a picture of the side the button goes on. I didnt think to document until later.. had sent this picture to my wife to complain. I think i put the spring in wrong though because it doesnt flick the key out quite right.. but too lazy right now to open it up again.
Old 11-12-2013, 07:13 PM
endless_corners
Ok a member pm'd me re: how to get it open so here are some photos that may help. Also a note when putting the spring back make sure to get the spring ends in the notches and twist the blade the opposite direction of how it comes out to pre-load it. Otherwise it wont spring out when you press the button.
Old 11-12-2013, 10:32 PM
TGED
TGED's Avatar
The key in the photo is pre 2011, the forum member who needs help has a 2011, the key is completely different.
Old 11-12-2013, 10:38 PM
endless_corners
I dont see how that matters considering the original thread was from 3 years ago. I am just trying to help future people. And it was the second poster who mentioned 2011. I think its nicer to have less threads than more IMO.
Quick Reply: Key fob problem URGENT PLEASE HELP
