PCM display
PCM display
I’m sure this has covered before but I was unable to find much results doing a search.
I have a 2005 Cayenne Turbo and the PCM display is to the point of being unusable. So I’m just looking for options. Is there a fix to the issue? After doing some research it seems that it’s a known issue and it’s a cable problem. Can anyone point me to some instructions on how to repair this?
I would like to install an aftermarket stereo one that would have CD/DVD/Satellite/Navi. I don’t really mind losing the steering wheel controls or losing the instrument cluster display options. However I would like to be able to use current wiring to antennas speakers etc.
I understand that Cayenne uses a MOST bus connection but it’s my understanding that it only connects to the CD changer and Navi system (which I don’t mind giving up) how difficult is a aftermarket head unit to install?
TIA
TIA
It also connects to the amplifier. What about your unit is unusable? I would personally consider getting another PCM unit off ebay or off this list than to yank everything out.
Thanks, yes I would want to keep the amp connections. Of course in the past I’ve had cars where a harness kit was available to take care of this.
It’s just the LCD screen that’s going out; mostly it’s just a blank white screen.
member name is roxboxxx - videos are in parts
here's the first - check the other videos in the the right side:
http://www.youtube.com/watch?v=A93lzls295c
hope this helps..
hope this helps..
Cruisin'
DO you have the part number for the screen. My screen went out as well and I have no problem doing the work myself but I do not know what screen to order.
Rocky Mountain High
Most of the new aftermarket units now support steering wheel controls, so if you decide to go that way, you'll still have a fully functional wheel. Kenwood and Pioneer both have some good options.
