What I did to fix check dipped beam errors and headlights flickering or going out.
Thanks for your response, I have tried everything suggested but still have the problem on the left front lamp. Maybe mine is not related to this issue and is the leveling sensor. I do not get the dipped beam warning only some fluctuation of the lamp up and down. I will update once I figure it out.
My right xenon lamp was flicking up and down not too long ago.
It was an early indication that the lamp was failing.
I replaced the bulb and defect cleared.
To confirm, just swap the left and right D1S xenon bulbs and see if the defect transfers.
These are the same ones I believe you would get at the dealer for closer to $200 per lamp, so $85 for the pair seemed pretty good, have had them 2 months now and only once have I had the reset.
http://www.amazon.com/gp/product/B00...ef=oss_product
Sylvania 39663 D1S HID - High Intensity Discharge Lamp, Pack of 1
Other products by Sylvania
4.7 out of 5 stars See all reviews (3 customer reviews)
3 Reviews
5 star:
(2)
4 star:
(1)
3 star: (0)
2 star: (0)
1 star: (0)
› See all 3 customer reviews...
Share
List Price: $56.00
Price: $38.81 & this item ships for FREE with Super Saver Shipping. Details
You Save: $17.19 (31%)
o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o
Temporarily out of stock.
Order now and we'll deliver when available. We'll e-mail you with an estimated delivery date as soon as we have more information. Your account will only be charged when we ship the item.
Ships from and sold by Amazon.com.
2 new from $38.81
Update: Switched bulbs, problem continues, did this update as suggested and still problem continues, cleaned contacts and it still continues. The problem is only on the left front so I have ordered a new wire harness for that side and will see if that is the problem.
Do you have to remove the air box to get the back of the wire connection off the tray? I have still not received any errors, just the up and down random flickering/leveling. The Saga continues.
I suppose you could also try interchanging the headlamp control units inside each headlight assembly to see if the circuitry is ok
That is the plan if the new wire harness does not make a difference.
Another update: Give me your thoughts on this one. Wire harness was not here yet but I was changing the oil so I had some time to mess with the lamps again. Decided to swap out the ballasts from right to left just to see what would happen and if the problem would then move to the right lamp. Everything seemed fine yesterday and no movement of the lamps. This morning on the way to work, both lights are now randomly self leveling instead of the just the left front. Not sure how the system works but they probably run in sequence so maybe it is the right ballast/control unit causing the problem. I will swap the control units back and see if the problems go back to just the left lamp. Still no warnings or dipped beam messages.
Wire harness should be here today, still trying to figure out how to remove the back of the plut without taking everything apart, any suggestions?
Received the wiring harness but it appears to be the wrong one! It is missing wires on the bottom right two holes, seems it may not be for the xenon lamps and may be for the halogens. I will have to send back to get the correct part or maybe it's been updated and those pins are not needed, don't think so.
The part number is the same as the one listed at the beginning of the post.
Changed the pig tail connection and the problem continues. Unfortunately it is ramdom and does not happen all the time which makes me think that maybe it is not the sensors. If I drive the car during the day and put the lights on in the evening, the problem does not seem to appear. I take my daughter to school in the morning and this is when it seems to happen the most. Thinking it was the battery causing the problem, I put the battery on the charger over night but the problem continued in the morning. I guess it could be a bad cell in the battery causing some type of voltage drop causing the lights to self level. Any thoughts on this being a battery problem?
A month a go, my right headlight was whacked by a flying barrel lid on the highway, which led to that light and my bumper getting replaced with a turbo one
If anyone wants a slightly worn 2 part S bumper, with broken passenger side fog light mounts, let me know.
Anyways, I have a passenger side light if you want to cannibalize it for parts, maybe one of the motors has a circuit/coil issue in yours? This was the one that didn't have any problems. Would be nice to get to the bottom of this, as mine does it once in a while too still, thought not as bad as before. Would save you the cost of replacing the whole headlight, it is a little tight in there so not sure what parts you can pull.
Thanks Touareg! I will give it a shot and see what happens.
Love the Turbo front end, How involved was the turbo replacement? Maybe that is what is wrong with my lights!
All the parts are posted somewhere on the forum. I didn't get the turbo inter cooler ducts, so if you look close at the pic you can see the smaller fake ducts from the S behind the grill. I decided to go with the sensor holes being filled. My guy assured me there would be no problems. Took him about a week to paint prep and put it on.
