Pig starts runs a bit, sputters and dies... HELP!
Old 02-07-2010, 02:50 PM
littlejt1
littlejt1's Avatar
Default Pig starts runs a bit, sputters and dies... HELP!
Symptoms are pretty much as above. Was running fine, parked at the airport last week, drove home fine Thursday night, ran fine Friday. On the way home from the game last night I stopped to grab a drink, left the lady in the car with it running, came back and it was not. Re-started, seemed OK, got ready to pull out and it sputtered and died. Finally made it home. Have started it in the driveway a few times this morning...starts fine, runs a bit smooth, then drops to low idle and sputters and dies. Will restart every time so far... ?????
I ran my code reader and it's showing no codes, so I'm at a loss.
Any help would be great.
Old 02-07-2010, 03:06 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,246 Likes on 782 Posts
Bad fuel maybe? I've had this issue on other vehicles. Eventually it will throw a CEL for misfires...
When yours runs, does it always run smoothly before it dies?
Old 02-07-2010, 03:24 PM
littlejt1
littlejt1's Avatar
Yep.. just started it and tried to drive around the block... runs fine when you give it gas and it smooths out. once you come to a stop and get ready to take off it sputters, dies. Restarts easy then repeats.
Old 02-07-2010, 03:25 PM
littlejt1
littlejt1's Avatar
I'm afraid to really drive it anywhere...but part of me wants to get a fresh tank of fuel.
Old 02-07-2010, 03:46 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
If Pops were here, she would say 'fuel pump'...IIRC, this problem has been discussed before by a few other members here in the P!g Pen...
Search some of EnigmaWmn's threads and you should come across it...or send a PM to Porsche52...I'm sure he's come across it a few dozen times by now.
Old 02-07-2010, 05:31 PM
Red1
Red1's Avatar
Jeff,
Answer your GD phone.
Change your fuel filter and call me.
B
Old 02-08-2010, 12:27 PM
porsche52
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
porsche52's Avatar
I would say it is probably the left side fuel pump. The symptoms match. A good way to verify is to pull the relay for the left side pump, if the car runs and does not die, then you have confirmed that the left side pump is bad. The fuel filter is a "lifetime" fuel filter as per porsche. If you want to replace it, it is integral to the right side fuel tank hat, both hats will have to be removed to R&R the left side pump. If it is not the pump, I have seen faulty MAF sensors cause a similar symptom.
Old 02-12-2010, 03:28 PM
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I am leaning to the MAF bring your problem. When you start it is it idling at the right rpm or is it alittle higher then normal?
Old 01-18-2012, 04:38 PM
STRICTLYPRO
3rd Gear
STRICTLYPRO's Avatar
I have this issue. The fuel presure drops and the car dies. Where are there relays you are talking about? Where is the best place to get the pump after i verify whitch one it is?
Richard
Old 01-18-2012, 06:00 PM
STRICTLYPRO
3rd Gear
Been looking around and found when I remove relay 1/6 the car will stay running. Anyone know what pump is bad? And how bad will it be to change?
Old 01-18-2012, 07:27 PM
cordsig79
cordsig79's Avatar
Richard, PM him..........your number still could be trolled............and put up on some nefarious CL ads or 4chan.
Old 01-19-2012, 08:40 AM
Nana's_914
3rd Gear
Nana's_914's Avatar
Seems like you are right on schedule for a new primary fuel pump (driver's or left side). I just replaced mine. I opted to change my fuel filter too, since it has check valves built into it that can fail and it was only $70. Changing the pump was easy enough once I knew where everything was. Hardest part was removing the seat brackets that cover the pump access covers. You need to get a M10 triple square or serrated wrench. The one I found at Napa was a POS and I had to get another one half way through the job, because the first one broke after removing the first few bolts. Once I got both brackets loose and flipped out of the way I cut the carpet circles loose with a razor along the perforations. Under the access covers there is another obstacle; to get into the tank requires a special tool. I decided I didn't need it, I used a hammer and screw driver to loosen the filter and regulator retainers. Worked fine. The electrical connections on the filter and regulators were a little tricky to get off, but easy enough with a small angled pick. Once in the tank I noticed that I had too much fuel in the tank to comfortably work in the tank. I rigged up a transfer pump using an old carter fuel pump and transferred the gas to my other vehicle. You need to route fuel lines from one side to the other, getting all the gas out helps make the job more pleasant. I used some string with slip knots to help get the lines back and forth. The fuel pump housing is a snap to remove and reinstall...right tight,left loose. Watch the hose routing near the fuel level sensor so the float doesn't hang up.
Old 01-19-2012, 10:19 PM
seankrider
seankrider's Avatar
If you haven't resolved this yet, I will attest that one of these threads says exactly which fuse you can pull to disable the likely suspect (left?) pump. If you pull the fuse (and disable the pump) and the car runs fine, you've found the cause. Off the cuff, something like 14, 15, 16 on the left sounds right...
Old 01-20-2012, 10:14 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
FWIW, Porsche52 (our P!g trauma surgeon and grief counselor) hasn't been active on RL for quite some time
Old 01-20-2012, 04:17 PM
STRICTLYPRO
3rd Gear
I got the pump,did the install with no issues. Thank you all for the advice on getting my problem solved. The total cost under $300 cant beat that!! Thanks again.
Quick Reply: Pig starts runs a bit, sputters and dies... HELP!
