Trans. thump noise?
Trans. thump noise?
Hello,
After a month of ownership, I am sorry to report that I am experiencing typical issues with me C-S. A little disappointing to say.
I am getting a thumping noise from my tranny that I have not read before here. I spoke to my dealer, and the service advisor stated that "they all do that". Just wondering, anyone here have this problem.
I would be coming to a stop from say 40mph, the car slows down to about 2 to 5mph, then I give it gas to go again (like rolling stop at a stop sign), and THUMP...it feels like someone rear ended me, and the car accelerates again. This happens only once in a while.
My service advisor said that it's normal and that I just happen to give it gas between gear change (??), and that is why I hear the thump.
Any thoughts?? Thanks in advise for your advise.
It's possible the driving style memory is causing that. I get it in the morning from a cold start...the car stays in first gear to a higher rpm then thumps into second. Try resetting the driver memory.
Turn ignition to ON , but don't start engine, for 60 seconds, then OFF for at least 10 seconds. Then start engine and allow extra idle time before driving off.
They also had a TSB ecu reflash for the slow turn lurch when turning and then could also thump. I had my done and I don't get the lurch or thump anymore...
