Wider front track than rear???? - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 12-30-2016, 11:17 AM   #1
Gus
Gus's Avatar
Default Wider front track than rear????
I drive a 964 Narrow body and am contemplating moving the front suspension setting to the outer or wide body position. I followed Jim Hall back in the 60's and 70's and he was a supporter of a wider front track over the rear track.
When they developed the 917, Porsche increased the front track width to improve handling with the increased HP. So there is validity to having a wider front track over the rear. My question is - "Has any one today experimented with a wider front track??" If so, what have you found?? My interest is in the handling changes that would come about if you made the front fracker wider than rear in a rear engine car (911) vs the changes to a mid-engine ((Cayman).
Here is some interesting info that is a quick read-
A wider front track effects handling in a number of ways. Assuming that all other things remain the same...
1) A wider track will make the springs feel weaker since you will be using a longer lever on them. So a wider front track will make the front suspension feel softer, promoting a reduction in understeer.
2) A wider track on one end of the car rather then the other will affect the way that load is transfered when cornering. When Porsche developed the 917/10 out of the 917K, they had a number of handling issues, one of which was power oversteer (going from 600 to 1000 HP -- duh!!! ). When they developed the 917/30, they actually reduced the rear track some. So the changes looked like this...
Track Front/Rear (rear as a % of Front)
917K 1564 mm / 1584 mm ( 101.3%)
917/10 1620 /1638 ( 101.1%)
917/30 1670 / 1564 ( 93.7%) (Frt is 106 mm wider)
The result was that when cornering, the load would be transfered to the outside front wheel sooner then the outside rear wheel since the front wheels had a wider track and thus were traversing a longer distance for a given amount of body roll. This will tend to reduce oversteer.
3) A wider track will lower the roll center at that end of the car, thus making it softer in roll. This is because the car's CG will not change, and thus the vertical distance between the CG and the roll center at that end of the car will increase, kind of like using a torque-wrench with a longer handle that pivots at the roll center. So a wider track at the front will make the front softer in roll which will once again tend to reduce understeer.
4) A wider track will tend to reduce the load transfer to the outside when cornering, which in general will increase cornering power since you'll be able to get more traction from the inside tires. So once again, increasing the track at the front will tend to reduce understeer.
So in general, making the track wider will increase cornering power -- but -- it is important to maintain an optimum ratio between the front and rear tracks as a means to managing the load transfer from the front to the back, and thus the resulting balance between the two ends of the car.
Now, widening the track using spacers also does a number of other things to the geometry...
1) It increases the front scrub radius, which can increase the steering effort and affect the feel and kickback.
2) It can increase the load on the bearings since the load will be cantelivered further out then the suspension designer may have intended.
3) Without working out the geometry, I'd also be concerned about causing the suspension to pick up a tendency to change track under bump/rebound which can cause all sorts of sudden strangeness in the handling as the suspension loading is changed.
Gus is offline   Reply With Quote
Old 12-30-2016, 12:48 PM   #2
959fan
User
959fan's Avatar
seems like you're talking about wider track via. longer A arm. a better way to me seems to be retain the full stock geometry, but physically move the mounting points out entirely. that way you will retain most of the original feel, but gain the benefits of wider stance/track. i'm would imagine that is how 917 is done.
are you traction challenged up front? why are you considering this? seems like you can greatly increase rim/tire width before having to mess with the geometry.
Honda FWD race cars are indeed wider front track than the rear. actually i'm building my Honda with goal to break Street FWD record next year. i will be running 285 mm width tire up front and rear will be probably 255 mm or 235 mm wide... that's all it needs since weight distribution is about 62/38%...
959fan is offline   Reply With Quote
Old 12-30-2016, 02:05 PM   #3
Gus
Gus's Avatar
On the 964 there are 2 suspension mount points for the font "A" arms. For the narrow body the inside mounts are used and for the wide/turbo body the outside mount points are used. If you use the outside points you need to reverse the upper strut mounts to keep all geometry the same. What you are gaming is about a 3 inch wider front stance, which should give you better handling and reduced over steer which is what I am looking for
But, if you do this you need to change to wide body front fenders and nose as the wheels will no longer fit in the wheel well. I am running 235/18 on front on an 8 inch rim. This is the max I can fit right now, going to wider settings would allow me to go larger..
Old 12-30-2016, 08:10 PM   #4
959fan
User
959fan's Avatar
ahh do you have any pix of this? i'm not super familiar with porsche susp so this is something new me. sounds very cool. all 964 have this feature? or are all 993, 996, 997, 991 are also like this? since there are always narrow and wide body for each generation of 911's...
Old 12-30-2016, 10:42 PM   #5
Gus
Gus's Avatar
Pretty sure 964 and 993 have this set up as front suspensions are the same - tears are different. Not sure about later models.
There are 3 mount positions on the cross bar that allows the lower "A" arm to be moved in or out by one space. Once you move the bottom out then you need to flip the top start mount to move the up position out to match the bottom move. This keeps suspension geometry the same. Will get some pictures and post .
Related Topics
Thread Thread Starter Forum Replies Last Post
Experiment - GT4 Track Setup Wiki: myBailey07 GT4 422 Today 11:43 AM
Handling issue discussion. mark kibort Racing & Drivers Education Forum 177 01-16-2016 09:34 AM
OFFICIAL: 2016 Porsche 911 [991.2] MJones 991 399 01-03-2016 11:54 PM
Changing back to stock swaybars due to stiff springs? Kaizu 996 GT2/GT3 Forum 0 10-24-2011 05:20 PM
Stiffer front antiroll bar reduce understeer ? (The paradox) Sanjeevan Racing & Drivers Education Forum 27 06-30-2005 03:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
