Help me identify an aftermarket racing clutch from a 996?
Old 12-06-2016, 01:17 PM
shdggsdv
2nd Gear
shdggsdv's Avatar
Default Help me identify an aftermarket racing clutch from a 996?
I'm a parts re-seller and I'm hitting a dead end with this part. I believe it attaches to the clutch? (I received it with a full Sachs clutch kit from the car)
Edit: So turns out the clutch kit is a SACHS for a 2011 997 GT3 RS
All I know for sure is that it is an aftermarket track racing part with less than 5k miles and pulled off an 08 996. Markings:
EMT
Charge 20264-13017C
11/2011
So any idea how I can identify this?
Old 12-06-2016, 01:31 PM
Aspen Autosports
Former Vendor
Aspen Autosports's Avatar
Its a Flywheel.
I hope you just had a typo when you said 08 996. It would have been a 997 at that point but it has 9 bolt holes so it is not possible to put on a 997 unless it is a turbo or GT3.
I see some of a part 964 102 239 XX (the x means I can't make out what it actually says.
So with all of that being said that is a flywheel off the 997 GT3 RS, possibly the 4.0L.
Old 12-06-2016, 02:15 PM
shdggsdv
2nd Gear
shdggsdv's Avatar
Originally Posted by Aspen Autosports
Its a Flywheel.
Yes, 997 was what I meant. Thank you very much. The last two digits are 81, which tells me 997 GT3 RS 4.0
So awesome, thanks for the help!
Quick Reply: Help me identify an aftermarket racing clutch from a 996?
