Max. front axle to rear axle height
I have completed Pss10 install and am setting ride height. I know how to that and all or so I think.
Question is according to page 44-3 of chassis manual number IV max. front axle to rear axle height difference should be 10mm. There is more information on page 44-11.
Does that mean if front reference point to floor is 130 mm. then rear reference point must be 120mm.
When I searched I did not find anything that indicated to set reference point at rear axle 10mm lower than front.
No - rear should be 10mm higher than front. The best is to measure rake angle on the door sill. I have a 964 and am now running a 1 degree rake angle with front being lower than the back. Hope this is a little help.
