Lightweight battery, viable option?
This seems like it would be a great way to knock a decent amount of weight off of a Porsche. The question is can it be relied upon? I never use the radio and I have a maintainer, just wondering what you guys think. I'd love to get the Porsche battery but they would have to lower the cost to interest me. This one is not as light but clearly lighter than a lead acid battery.
http://www.summitracing.com/parts/ODY-PC925
Have used the pc925 for years in many porsche racecars. Very reliable. Need new intelligent charger. The last about 2 good seasons.
Sent from my SM-T217S using Rennlist Forums
I had an Odyssey battery in my Turner race car for 5 years. Used with generator for a few years, then charged as needed with battery charger when gen. came out of car to save weight.
It was a small one. See photo.
This seems like it would be a great way to knock a decent amount of weight off of a Porsche. The question is can it be relied upon? I never use the radio and I have a maintainer, just wondering what you guys think. I'd love to get the Porsche battery but they would have to lower the cost to interest me. This one is not as light but clearly lighter than a lead acid battery. http://www.summitracing.com/parts/ODY-PC925
Rennline sells a nicely made adapter to let you mount it in the stock location. On the cayman I had to mount the battery as far to the drivers side in the adapter, as the cable on that side isn't that long. I also had to loosen the bolt where the cable mounts to the car and swivel the L-bracket to get a touch more extension.
I can't say that I feel the lost 25-30 lbs that rides high in the chassis, but there aren't that many places you can ditch 25+ lbs for that little $ That battery is also AGM, so no venting needed, as an extra bonus.
I used a pc680 for two seasons of auto crossing in a gen1 cayman s without issues. That battery would not start the gen2 987S at all. Switched to a pc925, and it has worked great, I hated the 10lb increase, but it has much more capacity. The rennline mounts make for an easy swap.
My usage involves prolonged sitting in the garage, a top off charge with a 2.5A battery tender before events, then lots of starting, short runs, and idling with the cooling fans running. No issues even for 4-5 days of this kind of running.
I had a LW odyssey in my car.. I didn't like the fact if I left the car for 4 days it would go flat.
yes don't tell me that's what a maintainer is for.. but seriously a regular battery can last a month.
If you car is a daily, I wouldn't suggest a lw battery unless you do not mind plugging in a maintainer on the days you do not drive the car
Used PC680 in my NSX for a couple years. It is mounted low in the front behind the spare. Although I removed the spare tire and bracket at the same time I reduced the battery weight, it certainly made a differnce in steering feel on the manual rack. I drove it once or twice a week. If I was parking it for more than a week, I put a tender on it. It never failed to start. I now have a Braille li-ion in my M5. Not cheap at $1400 or so, but I have treated it just like the stock lead acid unit and have not had a problem since installation year ago. 6lbs of li-ion that effectively replaces a 65lb stock battery.
I used very successfully an antigravity (li ion) for two months, and then, it broke (Lost all cranking power).
no idea yet what did happen, currently in warranty return, will see.
6 lbs
$220
7 year lifespan
I'm pretty sure there are enough serious buyers on rennlist alone to fund the project!
https://www.indiegogo.com/projects/o...battery#/story
$220
7 year lifespan
6 lbs
$220
7 year lifespan
$220
7 year lifespan
i was also thinking about a lightweight battery for my Spyder. not that porsche one.. there are many lithium options out there.
what are pros and cons if anyone has tried one? it seems like they need to be on a trickle charger.. is this EVERY night or can you park your car somewhere and still have cranking power the next day? 30lb is a lot of weight, and for $2-300 seems like a great deal. the porsche one for $2300.. not so much.
I have a shorai battery on my racebike.. but that doesn't really count.. it lives in a storage spot with a battery tender... have never tried in a car.
I use a shorei in my 997 Cup. Largest one they make for motorcycles. It's lithium ion and has always been great for last several years. I put it in a trickle charger every now and then. I only went down this route once the GT3 de guys had said it was working no problem.
It weighs under 5 lbs and costs $300 I think!
