Got my Moton Motorsports 3 ways in the mail. Need to know pressure for canister. Cannot get hold of Moton in NL for the last week. the website doesn't work on the downloads. Si would appreciate if anybody could give a hint. Its for a 944 full race at 1040kg / 2280 lb springs are 120 (680) fr and 170 (970) rear
The gas pressure setting you should start with depends on the O.D. of the piston rod in the shock. If you have the 22mm one, the recommended starting pressure is 185psi. If you have the 14mm one, the recommended starting pressure is 275psi.
