Big Reds...
Old 06-26-2007, 11:01 AM
demonfish
demonfish's Avatar
Default Big Reds...
Are they the same on the 993 TT as the 996??
as in part no's 993 351's the same fitment \ size etc as 996 351's
Old 06-26-2007, 11:44 AM
Geoffrey
Geoffrey's Avatar
No, 996 has monoblock style calipers, 993 are two piece calipers.
Old 06-26-2007, 04:36 PM
demonfish
demonfish's Avatar
ok thanks!!
i'll get to the bottom of all this brake stuff one day...
Old 06-27-2007, 10:41 PM
TheSpeedDemon
TheSpeedDemon's Avatar
You don't need any brakes on the M40 that is until you hit the M25 parking lot
Old 06-28-2007, 08:52 PM
SGOGT4
SGOGT4's Avatar
Geoffrey - Is there a benefit to the monoblock design over the two-piece? Also I have toyed with the idea of putting big reds on the front of my 930 but worry about the braking balancing being thrown off if I leave the stock 930 calipers in the rear.
Old 06-28-2007, 09:56 PM
Geoffrey
Geoffrey's Avatar
The monoblock calipers are more riged so they flex less than the two piece 993tt style. You'd want to match the front and rear calipers on your 930. I don't think it would be a good idea to leave the 930 rears on there. I did the complete conversion on my 700hp 930 and always felt that the stock 930 brakes had a much better feel and a more solid pedal (due to the master cylinder size of the 930 M/C). The only reason I changed to the 993tt calipers was that I was going through pads so quickly with the stock setup. I also ran a brake cooling duct kit which helped trememdously.
Old 06-30-2007, 10:48 AM
SGOGT4
SGOGT4's Avatar
Quick Reply: Big Reds...
