rs suspension info!!..lowering mods
Old 06-17-2007, 10:12 AM
stu.p
stu.p's Avatar
Default rs suspension info!!..lowering mods
hi
i own a 1992 964 turbo 2 and with the bilstein eibach set up i have just fitted i cant get the front to the lower height i require(platform screwed down to bottom).. it still measures too much from ground to wheel arch lip!....my rear is fine and has plenty adjustment left,only the front is the problem..
i am wondering if the rs 964 with its low ride height has any parts in the suspension i could use on mine to lower it slightly more..e.g spacers?,different spring cups or top mounts or whatever?? or is there any thing i can fit or modify myself??...not looking for much more 3/4 inch approx
Quick Reply: rs suspension info!!..lowering mods
