Adjustable swaybar links for stock sway bars?
Lifetime Member
Lifetime Member
Are quality adjustable sway bar links available to replace they factory ones on my '86 Carrera? TIA, Chris
RL Technical Advisor
Hi Chris:
Well sir, the front cannot be made adjustable as the location of the bar lies almost in the same plane as the A-arms. Not possible.
AFAIK, nobody makes anything for the rear. Some people have fabricated some links on the rear but those were all one-offs and IMHO not worth the trouble.
Virtually everyone just simply installs a set of the early-style larger adjustable bars that have adjustable droplinks front & rear. I would recommend the TRG ones,.....
This is the only way that doing a corner weight session is going to be worthwhile.
Lifetime Member
Lifetime Member
Thanks Steve,
One of my rear links got squished and I figured if I replaced it (both) with some adjustable links it would allow me adjust
out any preload.
Chris
out any preload.
Chris
Hi Chris:
Its a good plan,........
Getting any preload out makes the car handle the same in left & right hand turns so this is no small issue.
I think you would like what the TRG ones would for your handling,.......
