Knock sensor monitoring
Old 06-17-2001, 02:31 PM
Pumped993
8th Gear
Pumped993's Avatar
Question Knock sensor monitoring
Can anyone recommend a way to visually monitor any knocking on a '95 993 pre-OBDII using existing knock sensors? I heard that one of the OBD pins delivers the knock signal directly from the ECU. Has anyone rigged it to an indicator (like a giant red light which comes and stays on until reset)?
Thanks for the feedback.
Old 06-17-2001, 08:14 PM
Protomotive
7th Gear
Protomotive's Avatar
Exclamation
Pin 11 (Ye/Gr) in connector X4/2 under your drivers seat contains the 'knocking yes/no' output from the brain.
If I recall right, it reads 5 volts when not knocking and pulls down to ground when it is.
We usually watch this pin on a handheld oscilloscope, but I bet you could probably use one of those 'noid lights' that they use for testing fuel injectors.
The signal is so fast that a standard light or led probably wouldn't light up unless the engine was coming apart.
You could also build a simple circuit with a latch that would output to a light, as you said, then stay on till you reset the latch.
Old 06-17-2001, 08:36 PM
Pumped993
8th Gear
Pumped993's Avatar
Post
Originally posted by Protomotive:
<STRONG>Pin 11 (Ye/Gr) in connector X4/2 under your drivers seat contains the 'knocking yes/no' output from the brain.
You could also build a simple circuit with a latch that would output to a light, as you said, then stay on till you reset the latch.</STRONG>
Thanks Todd I see you are in many boards at once!
Old 06-18-2001, 04:05 PM
David T.
David T.'s Avatar
Post
Thanks! That's great info.
Any idea where can I get info about other pins?
Quick Reply: Knock sensor monitoring
