Mark this thread as Unsold
HRE 546 wheels 18 inch
Category: Accessories
Price (no $ sign please): $2299
Private or Vendor Listing: Private Listing
Location (Region): Canada
Item Condition: Used
18x8.5 Front
18x12 Rear
The centers have been stripped and are ready to be refinished with clearcoat or paint.
Offset stock is 40 front, 30 rear. The centers have different depth, so if they are swapped front to back, the offset is 50 front, 20 rear.
Changing the wheel halves to a different width would allow you to adjust the offset further, to fit whatever model you have.
$2299 USD plus shipping
Thanks man. They are gorgeous in person. I have decided to go with a larger diameter on my 997 build, otherwise I would keep them.
I have been seriously contemplating picking up another Porsche, just so I could use them. That's when you know you have a problem.
Do you know what size barrel I would need to get the rear to 18x11 with an ET55. Would I need to buy from HRE. I'm just outside of Toronto so I could meet up with you.
Then, using the high offset centers on the rear, you would need to get a 2.5 inch outer and a 8.5 inch inner barrel to acheive an et55 and an 18x11 wheel.
If you use the high offset centers on the front, you would have an et50 up front.
Then, using the low offset centers on the rear, you would need to get a 2 inch outer and a 9 inch inner barrel to acheive an et58 and an 18x11 wheel.
Also, you could sell the old barrels to get back some cash. And no, you wouldnt need to buy from HRE. The standard 40h 18-inch step lip barrels will work. MSG me if you want to discuss further.
