Mark this thread as Unsold
FS: Sway bars 28mm / 19mm
Category: Steering & Suspension
Price (no $ sign please): $300
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 924/931/944/951/968
Location (Region): Midwestern
Item Condition: Used
Front sway bar is a 28mm solid that comes with Delrin bushings and mounting bracket gussets.
Rear sway bar is 19mm adjustable with Delrin bushings.
$300 for everything pictured.
That looks like M030 front and rear...probably the "old" true 30mm front bar. Good deal here.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
*has the Racers Edge delrin end bushing which is specifically made for the 968 M030 bar
*has the circlip on the end of the bar that was only used on the 968 M030 bar.
I don't see the H&R screened logo which is why I suspect this is a true 30mm front bar. A quick measurement would tell for sure. We've sold tons of the 30/19 setup over the years and it's a great, easy to install upgrade.
Hi Jason. The pic of the bar I posted is the 28.5mm Porsche ClubSport bar which is part number 944-343-706-31. It is a superceded part number to the original hollow bar 944-343-706-30. More expensive and more lbs ... you can't tell by looking at the bar but you can tell by picking it up
See http://www.pelicanparts.com/cgi-bin/...g_description= Pelican have picked up the change but not go the correct bushes listed. The superceded bar takes the same end bushes as the orignanal 30mm bar but some very stiff inner bushes which I suspect are ex H&R too part number 951 343 794 03, These are MUCH stiffer than the OEM inner bushes sized for the 30mm bar.
Ok, I understand what you're saying. We don't call it ClubSport, just the new 968 M030 bar which is H&R produced. We sell it in kit form with the correct new main bushings and we also show those separately at:
http://www.paragon-products.com/New-...343.794.03.htm
Another reason I think this is the old, true 30mm front bar is that Racers Edge makes the true 30mm main bushing white, and the new 968 M030 bar bushing in red.
