Mark this thread as Unsold
BBS RIMS AND TIRES - SET OF FOUR
Category: Wheels & Tires
Price (no $ sign please): $600
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911, 914, 924/931/944/951/968, Race Car
Location (Region): Midwestern
Item Condition: Used
BBS RA 15" x 7", 15" x 8"
TOYO RA1 225 50 15
Mounted Diameter: 23.9"
This RA1 tire and rim set is an inexpensive road or track package. RA1 is TOYO's highest performance rating for Wet Handling and Tread Life - re. Toyo RA1 specifications.
BBS RA model 15" rims are one piece cast alloy, 5x130 bolt pattern, bolt-hole center hub thickness is 24mm, 7" and 8" width, ET 23.3 front; ET 10.6 rear - same as the stock Fuchs. The "basket weave" design is very strong, and fits various model years in type 911, 944, 924. Make sure they fit your particular car.
TOYO RA1 tires in excellent condition. RA1's are manufactured with a tread design that varies in depth from outside to centerline. The two deepest threads measure 7/32" inch on either side of the center bar blocks.
I will deliver to you if within a reasonable distance from Cincinnati.
$600 TODAY ONLY + DELIVERY
