Mark this thread as Unsold
FS: 993/ 964 TPC Supercharger Kit w/ Intercooler + Extras
Category: Engine - Power Adders
Price (no $ sign please): $5500
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 964, 993
Location (Region): NorthEast
Item Condition: Used
I've had this supercharger installed on my car for the better part of 7 months. I've driven the car a couple thousand miles with it on, only about 500 miles actually building boost. It works as it is supposed to and I've decided to sell it for a very serious opportunity to buy a 914 w/ a 2.7 6 cyl conversion. I figure, I've got the 993 I always wanted and I can be very much content with the performance of the stock Varioram engine with a couple simple mods... so, I've decided to sell the TPC supercharger kit to get the 914 I've also always wanted
Everything about the TPC kit is great as it was offered from TPC, but (as you might know by my other threads) I decided to complicate things by opting for a stand-alone ECU, larger injectors, converting from Mass Air Flow air metering to MAP sensor (required for the new ECU) and convert to wideband lambda sensor. All of these things were really in preparation for a custom turbo system I had planned to replace the TPC supercharger at some point but now I'm kinda dead set on this 914.
I can help with some technical and install questions as I did the install myself. Kit is for a 993 but can be used on a 964 with a few modifications to the air intake system.
- $5,500. Comes with the Unichip Q and T electronics modules, the dual additional injector manifold w/ injectors, the MY95 throttle body and intake boot elbow, the air/water intercooler w/ pump, water resevoir and radiator... Includes everything (pulleys, belt, tensioner, mounts, etc.) except the heater duct (wasnt in the kit when I bought it). - I'd like to swap my drilled rear carrier (drilled for tensioner mount) for your un-drilled carrier as well... makes your install a bit easier but it will depend on your install timeline (unless you have a spare stock engine carrier laying around).
- $500 additional, I'll include the 3 PLX modules (wideband w/ controller AFR module, Boost/Vacuum module and dual fluid temp module) and PLX multi-gauge (DM100 OBDII), and six p-n-p 60lb Siemens Deka high impedance injectors.
- $1500 for the custom "Juuso" p-n-p tunable ECU w/ 3bar map sensor.
- OR... $7000 for the everything... plus shipping.
Any questions, please PM me here or email richpugh@comcast.net
Here's the pic of the kit parts and a few of my install and running...
Parts on the bench before install
I mounted the intercooler radiator in the pass rear fender well since I eliminated the stock style mufflers
Quick disconnects for the intercooler
Juuso's custom 88pin 96+ ECU, 3Bar Map Sensor and MAP sensor adapter harness plug
Video of it running.
Video of it being dyno tuned (not necessary with the basic kit, definitely necessary with the custom ECU, larger injectors and such)
As of today, I thought so... I took a deposit and had just finished removing all the parts before Christmas. I just spoke to the buyer who (with my total appreciation and understanding) has decided to pursue the project of converting his TIP car into a manual trans car instead of buying the Supercharger kit, so...
ITS BACK FOR SALE!!
It's all off the car sitting on my bench in the garage. I'd prefer not to ship it but I can. If youre within 100 miles of 21211 (Baltimore, MD) I'd consider delivering it if you buy me lunch somewhere
ITS BACK FOR SALE!!
Wow ... that looks really nice !
I have a friend who had one in his 993 try to talk me in to buying it for my 89 with a 95 3.6 transplant,it sure would make for a fun DE car with what, 350 HP at least ???
Watch out GT3's ... lol
Cheers
Phil
Cheers
Phil
Thanks for the offer! If you were local, I'd probably consider it.
