Mark this thread as Unsold
FS: tire trailer
FS: tire trailer
Category: Accessories
Price (no $ sign please): $350
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911, 924/931/944/951/968, 928, 964, 986, 987, 993, 996, 997, Cayenne, Cayman, Race Car
Location (Region): SouthEast
Item Condition: Used
it is a DEI utility trailer 40x50 with the 12" rims. I build it myself, quite time consumming job for the trailer alone, but then I added on top a piece of plywood and some plumbing piping surrounded by pvc pipe to secure the wheels on the trailer. I also have some metal loop anchor all around to tie your strap nice and easy.
The trailer has always been under a carport and is in perfect condition, no rust or anything. Only used for a couple of track event so certainly has less than 1000 miles on it.
The tire has LED lights and regular wiring to go with standard trailer light 4 connector plug. Also have a spare tire but wheel diameter is slightly smaller. I made a mistake buying it, but it will do fine for emergency.
You can stack 4 wheels on the front tubes alone if you want to add a toolbox in the back, but in the meantime I added another tube so that you can spread the load and keep the trailer tongue weight to a minimum.
I used to trailer this with my 996 and the will wood hitch without problem.
Right now I am NOT selling the will wood hitch as I still have the car.
The trailer alone cost me $500 plus tons of time to make it right
Local pickup only in Fort Lauderdale Florida area.
Fyi
FYI. I paid 350 for mine.
