Mark this thread as Unsold
Porsche 928 AT - 5 speed conversion kit
Category: Drivetrain
Price (no $ sign please): $3500
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 928
Location (Region): West
Item Condition: Used
Price includes crating for shipment. Estimated weight is about 400 lbs. Everything fits on a pallet.
Parts shown in pics:
Transaxle with Limited Slip Differential (1986.5 G28.11)
Rear subframe member
Foam shift surround
Clutch and Brake pad assembly
Clutch master bracket and template for hole in firewall (black)
Shift linkage with lever, **** and coupler
Clutch master cylinder with new blue hose and mounting bolts
Clutch slave cylinder with hard lines, flex lines and mounting brackets
Lower bell housing
Upper bell housing with pivit ball for throwout fork
Flywheel
Wire loom for 5-speed transmission
Transaxle mounts
Flexplate
Clutch disc
Rear drive shaft coupler
Front drive shaft coupler
Pilot shaft
Throw out fork
Throw out bearing with shims
Torque Tube
Not shown but included:
Hardware (nuts, bolts, washers)
Clutch pedal microswitch for cruise control
Throw out bearing guide tube
Flexplate guide pins
New parts not shown:
Throw out fork pivot ball socket bushing
Gasket for clutch slave cylinder
Pilot bearing
Shift linkage ball socket
Pressure Plate bolts and washers
