Panamera 2010-Current
22" Wheel and Tire Fitment Thread
Old 03-24-2017, 04:26 PM
Chedman13
Chedman13's Avatar
Default 22" Wheel and Tire Fitment Thread
Okay, I've compiled everything I could find on fitment as my primary motive is to not use a 25 series in the rear. I've already read another post that said nothing larger than a 29.0" diameter will not fit and it will rub. There were no other details. I know for sure that 29.9" diameter will rub in the front.
My hope is to try the two fitments that are in bold below. Any thoughts on if the 265/35/22 with 29.3" diameter will fit?
Stock Turbo II Wheels:
Front: 255/40/20 on 20"x9.5" with 65mm offset = 28.0" diameter
Rear: 295/35/20 on 20"x11" with 68mm offset = 28.1" diameter
My aftermarket wheels:
Front: TBD/22 on 22"x9" with 45mm offset = TBD" diameter
Rear: TBD/22 on 22"x11" with 50mm offset = TBD" diameter
Fitment that does NOT work:
Front: 285/35/22 = 29.9" diameter = rubbing in front
Rear: unknown, but irrelevant since fronts don't work
Fitments that MIGHT work (but matching tires can be hard to find):
Front: 255/35/22 = 29.0" diameter (no matching tire that I can find)
Rear: 295/30/22 = 29.0" diameter (no matching tire that I can find)
Front: 255/35/22 = 29.0" diameter (PIRELLI P ZERO NERO GT 280 AA A)
Rear: 305/30/22 = 29.2" diameter (PIRELLI P ZERO NERO GT 280 AA A)
Front: 265/35/22 = 29.3" diameter (PIRELLI SCORPION ZERO ASIMMETRICO 420 A A)
Rear: 295/30/22 = 29.0" diameter (PIRELLI SCORPION ZERO ASIMMETRICO 420 A A)
Fitments that do work:
Front: 275/30/22 = 28.5" diameter
Rear: 325/25/22 = 28.4" diameter
Rear: 335/25/22 = 28.6" diameter (PIRELLI P ZERO)
Front: 285/30/22 = 28.7" diameter
Front: 265/30/22 = 28.3" diameter (PIRELLI P ZERO NERO GT)
Rear: 315/25/22 = 28.2" diameter (PIRELLI P ZERO NERO GT)
Quick Reply: 22" Wheel and Tire Fitment Thread
