Panamera pad clunk/knock sound
Recently performed a four wheel brake job on my customers 2014 panamera
Got all the brake pads from a third party parts store that only deals in German car parts all oem quality parts.
Never had a problem with any of the parts from this place before, but this time it was an issue.
Just want to share what I found so maybe it can save someone else a headache in the future. Got oem rotors for front and back, rear trw pads and front jurid pads. Everything looked the same, but the front pads would knock if you applied the brakes light going forward or backwards, also could hear them over light bumps in the road.
I changed the anti rattle clips and caliper bolts when the job was performed, had the pads in and out a couple times, finally decided to get the pads from the dealer, pads looked exactly the same. When I installed the dealer pads I could tell that the clips are the top pushed down on the pads harder and fit a little tighter. Knocking sound was gone.
Anyone else ever have this happen with a different set of pads on these cars? I have used jurid pads plenty of times and never had this problem.
