Panamera 2010-Current
2015 Panamera 4 edition
Old 08-22-2016, 12:25 PM
newyorker
newyorker's Avatar
Default 2015 Panamera 4 edition
Hello,
I just picked up 2016 Pani 4 Edition with 3.6 engine.
Have few questions.
1. The center storage box under center armrest gets hot. Recently the temperature was hot around 95 but I never seen a car that storage compartment gets hot. Is this normal?
2. I get slight vibration on steering wheel and both front seats when idle.
Once car moves it is very smooth.
I have 997.2 which has same seat vibration but it is different engine.
Does any one know slight seat vibration on panamera v6 is normal?
I want to get some idea before I go to stealership.
Thnak you in advance.
Old 08-22-2016, 12:54 PM
Panaseeya
Panaseeya's Avatar
My GTS center console gets hot as well. I used to keep a hard drive with music plugged into the USB in there but switched to a solid state drive due to the heat.
Old 08-22-2016, 02:23 PM
newyorker
newyorker's Avatar
Was your heat from hard disk or from the car by itself?
It looks like transmission or exhaust is under the center console.
Old 08-22-2016, 02:48 PM
Panaseeya
Panaseeya's Avatar
The car itself. Although the drive did contribute a bit of heat, it's pretty warm without it.
Old 08-22-2016, 05:31 PM
cerbomark
cerbomark's Avatar
no vibration like that on my 15 Pana 4.
and I do know the feeling as I had it on my 911.
Old 08-23-2016, 04:58 AM
newyorker
newyorker's Avatar
Default Dealer checked and it says normal on vibration
I went dealer today, scaned and engine looks OK by computer.
I just checked other pani v6 edition model, had similar vibration which is strange because 15 v6 model was smooth.
Maybe increase 10hp changed setting and causing some vibration.
Any ideas?
Old 08-23-2016, 08:12 AM
justabout
justabout's Avatar
This motor has 90 degree v configuration which is not optimal for a v6. It may have balance shafts to help but there is only so much you can do. I traded my 4 for a v8 to get better smoothness (and power). I believe what your observing is normal.
Old 08-23-2016, 09:00 AM
cerbomark
cerbomark's Avatar
it appears you narrowed it down to the difference between the 15 and 16. my 15 is seriously smooth at idle.
Old 08-23-2016, 10:55 AM
newyorker
newyorker's Avatar
Probably right.
I tested 16 demo edition and it had similar vibration. But why on the seat and not in dash or steering wheel is my question. Maybe the exhaust is vibrating but when I checked at dealer, it looked ok to me.
Another member with 15 said that his car is perfect smooth.
Old 08-23-2016, 05:55 PM
cerbomark
cerbomark's Avatar
so we are talking about idle so it s not in the drive line. Engine mounts different???
Old 08-23-2016, 05:56 PM
irv09
irv09's Avatar
The center console gets very hot. My iPhone shut down because of the heat.
Old 08-24-2016, 03:07 AM
newyorker
newyorker's Avatar
1. So center console is normal then. I just removed electronics ipod, phone etc. from center console just in case.
2. Can I adjust idle RPM at dealer? It is about 700 . It is between 800 and 600. I am thinking maybe adjusting idle rpm will change the vibration behavior.
Tech said that he can not adjust idle rpm like mercedes where we can adjust it with star computer connected. I want to make sure what he is saying is correct.
3. It is very interesting that when I get loaner panamera probably 2012~2013, It had no vibration at idle. Like Cebomark said it was very very smooth. This is when my 997.2 had warranty and I used to get service at dealer.
Then I test drove 2016 Panamera 4 edition model, it also had similar vibration at idle like mine. Then I tested another 2016 Panamera 4 Edition at service department, it also had idle vibration.
So this means they changed something in 2016 model. It looks like computer program to me since one of the tech told me that Porsche optimized engine program to minimize emission control and it is causing idle vibration. I am not sure this is right or not but since VW had problem with their emission program, Porsche also changed program in 16 model to avoid
problems. I mean the vibration is very small so it is not somthing like misfire but I can feel the engine vibration on both front seat. Someone wrote a story about his panamera had vibration and dealer changed exhaust connecting point or somthing and it solved his problem. I wonder if this is my case.
Quick Reply: 2015 Panamera 4 edition
